Guy I went to change my oil the other day pulled the latch and nothing. Noticed that there was a lot of play in it. I had my girl pull latch while I was pulling on the hood nothing its stuck. Any idea of how I can get it open?
hood is stuck
maybe this will help
http://www.cb7tuner.com/vbb/showthread.php?t=184971
on a serious note though, it could be a snapped hood latch cable? I would get down to the linkage and where the cable runs to and see if it isnt busted somewhere
I had a similar problem. My issue was rust.
The latch woundn't budge at all.
I kept pulling and pulling. Then I used a needle nose pliers, which stretch the cable a lot and popped the plastic hooks off.
I also began pushing up and down on the hood, prying it with a flat head between the hood and grill.
Eventually it popped up. If not my next step was to start cutting the grill, and then the plastic the covers the hood release.92 DX Sedan - Auto
6" rule only counts on OEM steel hoods not carbon fiber hoods. You have to be gentle with then as slamming them down will create damage to the material holding the hood latch to the hood.Originally posted by BurtonRiderT6 View Post6" rule: Bring the hood to 6" from closed and drop it. That's all the force required. Let gravity work
. Sounds like you went HULK on closing it at some point.
Highly advised to use hood pins as well regardless of how good your carbon hood is. Dont believe me? ask my sunroof why she so cracked!
member ride thread
DIVULGE MOTORSPORTS
who dat do dat
