What does this code mean?
    i took my car to my honda shop and he said i had a check code saying fuel supply? he said it could be two or three things, clean fuel fuel injectors or fuel pump and other things. i dont want to pay money for extra stuff if thats not the problem.ive already changed the fuel filter,pcv valve, bought new egr valve- he also put a plate in it.it seems like im loosing a lot gas mileage because of my problem.or do i need to clean valves and throttle body of black carbon build up.i have 190k miles on it.any ideas?thanks
    if it was a code 41 or 43, it's a o2 sensor issue. It would also explain your crappy gas mileage,
      x2 on o2 sensory, get a denso/NGK/NTK only.. rockauto.com has the best prices iv found
        thanks.is there a guide somewhere to install the sensor?
          its simple, either its in your down pipe, right before your cat you unplug it and screw it out, probably need either a o2 sensor wrench or a adjustable wrench(and for the life of me i cant think of what its called -_-) and screw the other one in(put anti-seize on it, should come with the o2 sensor) and plug it in, reset ecu also, just take ground off battery and the back-up radio fuse out before you start and put back after you change
            You'll need to get one of these to remove it easily:
              I don't know about the rest of you, but my O2 sensors were ALWAYS bitches to get out! It'll help to start the car up and let the header/downpipe warm up, wherever your O2 sensor is located. Penetrating lube may make your job easier as well.
                Yeah, warmth and a good overnight soaking in PB Blaster will be a great help. Especially if that sensor has been in there for 20+ years.
