Need help from the crew. Went out this am to start the cb7 and the engine starts fine but then skyrocketed to 6000 rpm and won't drop even with the clutch depressed. Engaged into gears and then the brakes become heavy if non existent to operate. Need any help that can be given in the matter.
Engine starts @6000rpm and won't kick down
Check your throttle cable from accelerator pedal to throttlebody.
1993 CB6 Coupe Seattle Silver YR-94M
Originally posted by Acclude4gens are win. It's in the bible somewhere.
Members Ride Thread
1993 Accord Coupe- Summer ride
http://www.cb7tuner.com/vbb/showthread.php?t=130064
1995 Civic Coupe - Winter/DD
http://www.cb7tuner.com/vbb/showthre...53#post2744953
Originally posted by 90blackcoupe View PostCheck your throttle cable from accelerator pedal to throttlebody.
.... with the motor off, pop the hood, unlatch the cable from the piece that turns on the intake manifold and start your car, see what it idles at, if its fine, your cable is stuck somewhere along the lineEveryday is one day closer to completing my cb7 <3
With the car started, put your foot under the gas pedal and pull up, does it drop the idle? Take the intake tube off and look at the throttle body, with the car off, what position is the throttle plate? It should be slightly open. If it feels hard to move, spray it with some WD40 or something to clean and lube it.
