i removed my stock intake box and put a aftermarket filter in. But there still the inlet tube to the air box that i havent removed. It has a round plug or sensor in the top of it and a line going to a black box above. Then the black box has a plug on one side the a vacume going to top of intake. Can i remove this nd just block the vacume or do i need whatever the black box is?
intake question
it can be removed no prob just cap the vac
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
What engine are we talking about? We need to know that first to give a correct answer.Originally posted by roketdemon02 View Posti removed my stock intake box and put a aftermarket filter in. But there still the inlet tube to the air box that i havent removed. It has a round plug or sensor in the top of it and a line going to a black box above. Then the black box has a plug on one side the a vacume going to top of intake. Can i remove this nd just block the vacume or do i need whatever the black box is?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
if your refering to the black box mounted on the factory intake pipe by the battery it can be removed no probs, i believe its a silencer for the intake
You can remove everything associated with your intake tubes, even the black box on the passenger fender and all the vacuum lines. When you install your cold air/short ram, you only need 2 hoses. The one that goes directly to the valve cover and the small one that runs behind the intake manifold to the valve on the drivers side of the manifold, also known as the air boost valve.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
