My 91 has auto seatbealts an up until yesterday worked. It goes into open position then I have to pull it back until I open the door which then goes back into open. It wont retract. Any ideas or a fuse I can take out to make it stop goin into open??? Thankx
automatic seatbealt problem
check your door indicator (the little button that tells the car if the door is open). Does your interior light turn on and off with the door as it should? The other thing you can do is take it to Honda and they will fix it for free as it's covered under the "guaranteed function of the seat belts for the life of the vehicle" or something like that. If it isnt functioning properly, they must fix it.2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
check the indicator light black switch in the door jam, if its not that there is a switch in the track the seat belt buckle slide on toward the windshield, the third switch is locted in the lock itself on the door this one is the most likely the problem because as it becomes dirty it will begin to stick cause the switch not to work just need to clean it
