f22b1 engine mount?
    f22b1 engine mount?
    Im swapping my f22a with a f22b1 and i need to know what engine mounts to use.... the 94-97cd5 mounts or 90-93cb7 mount...
    what year is your car? and model
    rear mounts are different on some but the rest from 90-97 are all the same.
      91 ex manual tranny
        That is false.
        There is a DIY on the F22B1 swap in the Swaps section, written by darkcloud. Look for it.
        If you're removing a healthy F22A4 just to "upgrade" to the F22B1, don't bother. The F22A4 has more performance potential than the F22B1. The ONLY reason to do an F22B1 swap is if you need a replacement engine, and you happen to find a good one cheap.
          I have a 91 coupe with a manual tranny. the engine is f22a1 with 278,xxx and some serious oil leaking from the rear of the engine under the intake manifold. I'm only swapping to stay on the road not for performance... From what I've been reading the f22b1 doesn't have much to offer as far as doing any kind of build.
            For mild stuff, or for turbo, its fine... but if you wanted a serious N/A build, or if you were just doing it as a VTEC upgrade (lots of people get suckered in by that crappy SOHC VTEC), then it'd be a waste. But if your A4 is on the way out, and you're not looking for anything but a reliable replacement, it's not a bad choice. The swap is about as involved as an H22 swap, though.
            Not terribly difficult, but not as straightforward as another F22A.
              I read the thread in the swap section for the f22b1 but I'm having trouble figuring out what mounts to use..
                Perhaps STREET-SPEC actually was correct. It looks like the F22A mounts are what Darkcloud used. I'd send him a PM and ask him to clarify. Modification of the driver's site engine mount has always been a part of the swap, but he says he didn't do that... so now I'm curious.
                  Cool. will do. thanks for your help.
                    i thought the only differences were when they were switching to hydraulic mount on the rear and i just found out the drivers side is hydraulic for 96-97 model. i know i used a pass. side mound off a cd5 on my cb. the tranny mount and front mount should be the same. thats just from looking at the j/y though.
                      lil d do you have the oil cooler attached between your oil filter and block? I had to take mine off and replace the o ring to turn an engine that wouldn't stop leaking into a good one without replacing the engine
