ok i have brand spanking new drilled and slotted rotors and pads.. i looked on youtube to get an ideal of how to get the old rotors off and the new ones on but holy crap!! do you really have to drop the whole spindel? and take half the car apart to put these on? please help me im use to cars with floater rotors (vw) and this seems like a lil much thanks for the help and any advice
changing rotors
Suspension is actually MUCH easier. All you need are basic hand tools and a spring compressor (which can be borrowed for free from most major autoparts chain stores, like Autozone.) The rotors really are the only truly pain in the ass part of these cars when it comes to the basic stuff (actually, I can't think of anything else that's as irritating.) I've done my suspension about 6 times, and helped on a few others. It's cake.
One bit of advice on the rear suspension, be very careful when removing the bottom bolt holding the shock in place. If the bolt seizes to the bushing sleeve, it'll tear apart the bushing, which is a headache to replace. I have to fix that issue on my car at the moment.
Not sure. I haven't had my rotors done since 2004, and even then it was done by my stepfather's Chrysler dealership (yet i still paid for it...)
If you can, find a place that will do it for a flat rate, and not hourly. If you're lucky, they won't know what they're getting into until they've already started!
The EASIEST way I've found to do the rotors is, when you have the spindles off, take the 4 bolts out of the back that are holding the rotors on, take 2 10mm bolts that are 4 or so inches long, thread them into the OPPOSITE corners, take a hammer and hit the heads of the bolts with a hammer, switching from one to the other so the rotor comes off evenly. May sound ghetto or whatever, but, that's the easiest way I've found to do it with normal hand tools. I've done it a few times, the ONLY damage I've done was to some cheap bolts. No damage was done to the threads or any other part of the whole mess.
maybe my car was being nice but i pretty much followed http://www.youtube.com/watch?v=5xIUAMl-oRQ without air tools and i got it done in under an hour...i didnt take the whole knuckle off either just the bottom ball joint. the after taking the the axle nut off just rotated the knuckle to access those 4 bolts in the back. once that was done i removed those 4 bolts then got some longer bolts of same thread pitch. threaded them in where i took the 4 back bolts out, and hammered evenly around in a crossing pattern till the hub came out. make sure you loosen the four front bolts(not all the way out, just broke loose) . if you gonna attempt it u can pm me ill help you through it...
Ride List
1990 Accord dx coupe - my baby (dsm turbo set up in progress)
http://www.cardomain.com/ride/3202853
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled
newest 2006 mazdaspeed 6
http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
I dont know why people complain about these style rotors. I have done them many times by using longer bolts threaded through the back and tapping them out. Very easy. Takes me 30 minutes a side. Similar to nine_deuce's method
But, I work on cars a lot...so if you dont it will be harder for you =)What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
while if was off.
nine_deuce: I need to get one of those shirts for my girl. Hilarious.
