RPM question.
    RPM question.
    I have a 92 accord ex sedan and my reving is too high. She is an automatic. Around 40mph the rpm is at 2500 and its 2500 for mostly every gear. I swear sometimes it reaches 3000.
    My question is what's the normal idle rpm? And and at what rpm should I be in when I reach 40mph?
    Your RPM is dictated by your transmission's gearing. Normal operating range is between 2000 and 3000. This is a small 2.2L engine, not a big V6 or V8. It has to rev higher than those big engines would.
    Normal idle should be between 750 and 850. There is a thread linked in the "read here first" thread at the top of this section that tells you how to properly set your base idle (you read that first, right?)
      At idle I believe you should be around 750-800. At 40 mph it all depends what gear you are in. Being an automatic it depends on if the tranny computer is operating properly.
        Alright. Thanks for the advise. It was very helpful
