As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Brake Trouble
    Brake Trouble
    as of late my brakes and brake pedal have been feeling pretty off,
    desperately need to get it fixed but i dont know what the exact issue is...
    so here's the issue: my brake pedal has to be depressed pretty low to the floor to initiate any braking, and once they engage they have next to no stopping power
    **brake fluid level is good btw**
    and on top of that! i cant seem to un-seize the bolts that hold my front brake calipers on so i cant even buy new brake pads (according to every automotive store our cb's came with 2 different types of calipers..nissin and another brand, and im not sure which i have) so if anyone can give me some insight or advice to either situation it would be lifesaving! thanks!
    your master cylinder is failing. Its leaking internally and fluid is bypassing the seal in the piston, thus causing your sinking pedal.
    You have Akebono calipers if you see 3 symbols that form a triangle. Nissins if they say "Nissin" stamped on the caliper.
      It does sound as if your master cylinder is failing, get it fixed immediately. Also when buying pads, you can buy both kinds if you're unsure and return the ones you don't use.
      BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
      BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
      Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
      CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
        ask for a brake master cylinder repair kit at the parts store..should look like a repair kit for clutch slave..(spring and new seal)..after you have changed the seal on the master cylinder.post your work on DIY for everyone.
