I was looking at putting a rear sway bar on my 92 LX (Doesn't have one) and I saw the write up with using an EX crossmember. My question is (I couldn't find it via searching) does the Vigor's rear crossmember fit on the accords? I am not positive if they are the same or not. Other than the sway bar part. Thanks.
Acura Vigor Crossmember
Not sure.. the part numbers are almost alike so maybe it'll fit with a little modding.
50300-SM4-A01 Accord 90 DX
50300-SM5-G01 Vigor 92 ??
For all the trouble you're about to go through, wouldn't it be easier to install an aftermarket one. I'm pretty sure there is one that allows for you to drill and mount to your own stock cross beam.Last edited by Leung; 04-12-2012, 04:07 PM.
Possibly so but. I am looking at the cost right now. I have a limited fund at the moment because most of it is going into re-building a F22 so I can boost it. I can get it a lot cheaper at my local junk yard (the sway bar that is). I know the EX one will work with some modifications. I was just hoping since I will have to get that one maybe the vigor bolted right up.Originally posted by Leung View PostNot sure.. the part numbers are almost alike so maybe it'll fit with a little modding.
