f22b2
    f22b2
    So I am about to be swapping a 5speed out of 94 accord into my 91. I was wondering what the difference is between my f22a4 an the b2 if it would be worth puttin the motor in as well or just do the trans. i think the motor has more miles on it then my a4 but I it think its been took care of better then mine. My a4 smokes alittle an before i bought it from my sister she didnt keep the fluids changed like it should thus the reason I'm doing the 5 speed swap for the trans is slipping. My car has 190,000 miles the b2 has
    I dont know the car says 254,000 but the motor has writing on the valve colver an looks very clean to be a 254,000 mile motor i think it may be a junkyard motor so I'm not sure I need some input please
    The F22B2 isn't an upgrade in any way. You'd be better off keeping the engine you have, since you know the problems. An unknown engine could end up being even worse.
      ok I was just wondering I knew it was non vtec I just didnt know if there was anything special about beside a couple of extra electronic things on it
        The 5th gen Accord engines are all pretty lame when it comes to performance potential. They're solid, and good engines... but the F22A has far more potential.
