yesterday on the way to work i realized about 40mph the steering wheel is "ticking"or clicking and also felt it in the gas pedal. it's going like du du du du du du constant, light but very noticable and its never shaken before. it very bad when the wheel turns right "toward pass. side". even in a straight line, i turn the wheel a tad bit and du du du du du again. i have new tie rods so i dont think thats it. when the car is off, and i turn the wheel left and right it clunks like the rack and pinion is bad, but i'm sure this problem is coming from the pass. side.
i'm pretty sure my axle is bad, "moves in and out" but barely. and lower balljoints are shot. any help would be greatly appreciated. thanks.
did you change Inner/Outer Tie Rods or just the Outer? i know if you turn the wheel left to right & hear a clunk, chances are it's the Inner Tie Rod(s). & an easy way to tell if its a ball joint, get the vehicle off the ground & try to move the wheel at top & bottom (hands at 12 & 6, like a clock) if there is movement/play you should then be able to see if its the top or bottom Ball Joint or both... i had a weird creaking sound (when taking off, shifting gears & while turning) coming from my CB7 last week, ended up being loose bolts on Rear Engine Mount!..
