No tail lights when headlights are on.
    For some reason none of my tail lights are working. All of my brake lights work and my blinkers are working. When I turn the headlight on my tail lights won't come on. I couldn't find a fuse or nothing. What could cause that?
    are they supposed to be 1157 or 2057 light bulbs? I went to the auto parts store and they said 2057. When I look under lighting here it looks like it should be 1157.
      L2057 is the bulb you want. And it's more than likely the bulbs that are bad. Change them, and if you still have a problem check your wiring.
      BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
      BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
      Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
      CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
        check the electrical boxes that are mounted to your tailights? bulb leads. all fuses good?
          are there any fuses for the tail lights?
            pull the bulbs, make sure the base and the socket for them isnt all crusty. and use dielectric grease next time around...ive had this happen a couple of times, the bulbs are either crusty or the plugs to the boxes needed a wiggle..from there a volt meter will save you time.. and/or put juice to the bulb and check
              under the hood
                just wanted to post the fact that I had to replace a 15 amp fuse under the hood. It says "small lamp" it is the second down from the top left, of the fuse box under the hood. Thanks for the help guys.
                  push your fog light button on your dash.
                    very funny
