So I'm curious what this is ... Got my a/c swapped up to 134a as far as I can tell they didn't do alot other than the adapter kit but it blows cold as 40f ever since I got it done I've had a whine sound when I start the car with the a/c button pressed and the a out of the blue one tonight was I was idling for a bit and put the car in drive with no a/c no blower and it suddenly started the whine il try to record it but it only last 15 /30 seconds if that any ideas
A/c whine
Pretty sure it's not the belts no sounds under load while running the a/c it's just the start ups and the time tonight il get my deflection tool and check them though. Funny thing is it did it with no compressor load tonight all other instances make sence to a slipping belt
Missing MyOriginally posted by evil_demon_01Do it once, do it right.
Saving a dollar is not worth risking a life.
White -91 LX Sedan - leather converted
Mulberry 91 EX Sedan
The project 92
I wonder if those guys that did your retrofit added oil also. Since they put in 134a and our cars came with R12 from the factory, you might want to ask them if they added any ester based oil. Another thing is if they used PAG oil while there was ester oil in there, it's going to gum up everything in your system.
I think it's no 2, going to the mechanic to check ... He said no leaks the day I got it charged I'm gonna have him check for leaks it's inside like if the blower wasn't working right and I toggled the a/c on and off and it whined then nothing then whined every time I bet that valve is bad ... Atleast I'm still getting cold air I just don't know if it's a get it done ASAP thing or not does having a bad valve have any worse problems than just the sound ?Originally posted by 93_FSWAP View PostIs the whining coming from underneath the hood? or is it when its blowing that you hear it inside the car? if its heard inside the car then your expansion valve is the problem
The project 92
okay im confused .... tried losinging and tightening the serpintine belt and no luck , then it seemed to come from my fans area where the high pressure freon is so i jumped my fans at the thermo and they both ran fine its not in the car from what i can tell, its short 5 to 10 second sperts the longest was 20s not sure about the expansion valve becouse that would give me no cold air at all which im able to drive around cold air all day so i cant figure it out
The project 92
