Strut bar
    Strut bar
    Is this a good strut bar?
    http://www.ebay.com/itm/250906451498...ht_3586wt_1037
    Somebody said I should order one from the brand called Godspeed but I dont see that anywhere let me know
    Whatever the mind of man can conceive and believe, it can achieve. –Napoleon Hill
    Members ride Thread
    Instagram: IbSprintin
    You're better off with this.
    http://www.ebay.com/itm/1990-1993-HO...ht_2681wt_1037
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      why is this one better?
      Members ride Thread
        Has no flex points.
          Originally posted by ExplodingCake View Post
          Has no flex points.
          0oh i see
          Members ride Thread
            Originally posted by wildcatloe View Post
            0oh i see
            In my honest opinion , I would not even waste money on bars with flex/adjusting points.
              I have that one. With no flex point it's harder to put on but better performance. The Sprint sticker is no good. Won't stay on.
              The letters come off easily.
                The Sprint one is a more rigid design, as said, but it won't clear a DOHC engine. If you have a swap, or plan on doing one, then don't get that bar.
                The first one is a generic design. The DC Sports strut bar was the first to really gain popularity in that style. I have a Megan Racing knockoff, similar to that one, and it suits me well. Fits with an H22 swap.
                Either one will make some difference.
                  Generally speaking...Those things are a waste.
                  If you know anything about a cars suspension then you'll know they aren't worth a crap. What you should be focusing on is the anti-sway bars and rear strut tower brace not the front. What your going to end up doing to the car is making the front too stiff up top where it won't flex like it needs to and you WILL lose traction.
                  A more proper approach to suspension progression would be:
                  Larger front anti sway bar(solid not hollow people!, endlinks and bushings(poly- black is better for achieving a more squeak free install) grease the fuck outta them.
                  Rear Anti sway and poly bushings/endlinks
                  Rear tower brace.
                  Shocks and springs.( if you can't do both at the same time do SHOCK FIRST!.)
                  Front tower brace. If your really going this far then you should have one that connects to the firewal of the car for a 3rd anchor point. They aren't cheap but they are much better than the other 2 showed in this thread. the one Explodingcake showed is a good middle ground though.
                    Originally posted by ESP-net
                    CB 90-93 Accord 3 Point Front, 2 Point Rear, 2 Point Rear Lower GOLD
                    Explicit Speed Performance
                    www.ExplicitSpeedPerformance.net
                    Custom Engineering and Fabrication
                    Motor Mount Kits, Traction Bar Systems, Solid 2/3/4 Pt Strut Bars, F22/H22/H23 Alternator/Tensioner Kits and much more...
                    A triangulated rear brace would be good too
