Bleed the coolant system? Everyone will say it's most likely a vacuum leak, but my car did this when I took my whole intake manifold apart. I started it up and it rev'd from 2,000 to 4,000 nonstop. Must have gotten air in the lines cause when I bled it, ran fine after that. But it could also be a vacuum leak.
93 accord ex idle issues possible bad clutch?
does it do it when the clutch is out and its in neutral?Originally posted by Hyph3ma View Postty for your reasponse but im not worried about my idle it idels fine when clutch isnt pressed in this only happens with the clutch engaged either between shifts or when im stoped at a light or stop sign
Are you sure your not pressing the gas? There must be some wires you're crushing with the clutch pedal or something funky. There's nothing associated with the clutch system that could cause this.Originally posted by Hyph3ma View Postyes everytime the clutch is engaged even in neutral it pegs 4k but when the clutch isnt pressed in its completly fine it will idle around 1.5k steady with no fluxuationOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
itcouldbethattheclutchisntfullydisengagingitmaybed isengagingenoughforyoutochangegearsbutitsstillputt ingastrainontheenginethoughidontseethatmakeingitre vhigheriwouldexpectthatwouldcauseittodieouttheclut chisnotassociatedwithanythingvacuumoridlerelatedso theonlythingitmightbeiselectricalsincetherearesens orstellingtheecuwhentheclutchpedalisdepressed
That's kinda the point. It's very difficult to understand you as well, with made-up words and no punctuation. If we can't read your question clearly, how can you expect to get a helpful answer? In this case, when a helpful answer is given, it's given in a manner that is just as difficult to read.
There are real words in there. Look closely.
PIIYB!!!Originally posted by Hyph3ma View Postgo fuck yourself
Dude seriously this guy runs the forum actually he owns the forum. I know I know everyone at one point disliked the way the forum ran. Its a noob thing. But the forum is united and strong for a reason. If we let the site go to shit it will be like honda-tech real good info but you have to dig and dig cause people make so many stupid threads or are not wording themselves right. And if a few guys or mods tell you something it isn't to push your buttons.
Just dwell on that if you are banned. We still want you here just remember its a forum. Order needs to be in place.
No, we don't want you here. If you can't type coherently, and can't take a hint (I actually DID give you good information... and it was only a LITTLE harder to read than what you typed...) then you can post elsewhere. There are plenty of other forums that will be glad to have you. They might not be very helpful, but hey... it is what it is.
My job is not to make you happy.
