gas
    gas
    Ok guys. I notice when i get in my car i smell gas .. well i have a crack in my pipe n when i move my exhaust i know there's a rattling noise.. ...
    Could that be the reason or wat.. cuz i was reading the se archs n i notice alot of
    comments that it could be the gaskits n stuff...
    Any advice
    Keep It Low, And Drive It Slow
    89 CRX dx with a 94 del so Si swap - deceased 91 civic hatchback Si with a JDM ZC SOHC swap-sold 92 CB7 accord sedan - living but stock
    which pipe has a crack in it? I had a crack in my filler pipe, and I could smell gas......
    Exhaust rattling is probably just a heat shield.
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      Its right behind the muffler. N i thought it was cat that broke because on my crx i remember that happened to me n it was my cat broke inside.. well that's wat the muffler shop told me
        Sounds like you have two seperate problems. First of all you have to jack the car up to look under there and hit the exhaust to find out what's loose. Could be a broken hanger, could be a broken resonator inside of the exhaust, could be a broken cat, could be a few different things, hit the exhaust and try to narrow down where it's coming from. Also look at all the fuel and brake lines, our cars are getting older and rusted lines are becoming more and more common. Check the fuel lines and fuel filler neck, if your fuel line is leaking, there's a good chance your brake lines aren't too far behind.
          Ok dang... so how can locate the lines... wait aren't they under the car right
            Please make an effort to type more clearly. I can barely understand your first post, which means I can't understand your problem, and I can't help you.
            If there is a crack in your exhaust, that would not make things smell like gas... unless you were running incredibly rich.
            If there is leak in your lines, look for wet spots. Park somewhere you could see such spots.
            Check the connections under your hood for leaks... fuel rail, fuel filter...
              Check your gas tank too!... When mine went it had a hole above the seam at the back that wasn't visible until I got right under it. When I changed it I found out the very back of my tank was only paper thin or less... I found out when my exhaust sprung a leak and no shops would touch it because of the fumes... So I ended up changing the tank myself before I even got to touch the exhaust:/
              4000watts just so all the haters hear me comin!
                How yu scrap the tank is ur car dropped. Because mine is still in 4x4 mode lol...
