ok so i see everyone with just the generic MSD coils on there Honda's that you can get from any where. I want to know how to wire that up, i have a external coil accord and will be putting a h22 in it soon but how to you wire it up???
Msd Coil Wire Up
Are you installing a JDM H22? Because that will come with a distributor that uses an internal coil, and you will need to convert.
Honestly, unless you're making over 500hp, there is no need to upgrade any part of the ignition system. All you are doing is creating an opportunity for something to go wrong, for no performance gain, and very little aesthetic gain.
no its not a JDM block although i am putting a JDM head on the h22a1 and using stock external coil disy it is out of a 93 prelude vtec i have the hole car im just putting its motor into the CB7 and it has a full port and polish, aftermarket header, 2 1/2 cat back no cat, 6puck clutch sacs clutch and light weight competition clutch fly wheel. i also have ram air intake and no balance belt and was eventually gonna do nos so i thought while i am at it i would do MSD everythingOriginally posted by deevergote View PostAre you installing a JDM H22? Because that will come with a distributor that uses an internal coil, and you will need to convert.
