cd5 window motor/regulator in cb7: does it fit?
    So my driver's side window went out and I'm having a bit of difficulty finding a cb in my area that has one that works. I found a cd5 that is wrecked, and the guy is selling parts really cheap. Was wondering if anyone knew whether or not a cd5 window motor/regulator assembly would cross-fit? Any help would be appreciated...tired of getting rained on.
    Compare part numbers. If the part numbers are the same, it will fit. If not, I wouldn't think it will fit. If the geometry is slightly different, it won't work properly.
    I used a cheap aftermarket regulator, and I'm not sure I adjusted it right. It never worked properly, and resulted in the screws sawing away at the mounting holes. The holes are extra wide now. You don't want to mess around with a regulator that doesn't fit properly!
      I didn't even think about comparing part #'s...slow freight today. Thank you sir!
