Hey everybody,
Thanks to some help here I got my starter fixed for $0 and took my car out for a spin today! First time it has run in about 6 months.
First thing I took it for some fresh gas.
A few hundred feet after I took off from the gas station the car sputtered for about 5 seconds, then it picked back up and ran alright.
Is this likely from trash being stirred up in the gas tank from the sloshing caused by adding fuel? Or maybe a mostly clogged fuel filter?
The previous owner had run it out of gas and overheated the starter trying to start it. I know how bad that can be for picking up all the junk in the tank.
Are there measures I should take beyond changing the fuel filter?
Second Issue:
When sitting on a hill I was loosing brake pressure. All the way until the pedal was virtually on the floor.
Then after taking off the pedal would return and work okay.
Still can tell the brakes aren't 100% but I didn't figure they would be perfect right away. But losing pedal is a bit scary.
Second Issue:
