Trunk rust fix?
    Trunk rust fix?
    Ok I don't know the right term for the portion that needs repair, but the edges of the trunk opening where the rubber seal inserts rusted out and portions broke off so I have constant water leaks when it rains or wash the car, I need some ideas or opinions for How I can fix the problem.
    Are you able to provide a picture man? Kinda hard picturing exactly where your rust spot is.
      naw man no pics now, I'll probably post some later but, its the part where the rear windshield meets the trunk, where the water should drip in and theres a rebber to prevent water from getting in.
        bondo had the same issue, pull up the rubber seal remove the reamining rust and shape the bondo to match the edges, doesnt have to be perfect since the seal will cover it
        Hoonigan: a person who participates in any type of reckless driving including but not limited to drifting, drag racing, burnouts, doughnuts as well as acts of automotive aeronautics.
        MRT: http://www.cb7tuner.com/vbb/showthread.php?t=195250
          Ohh gotcha. There is a DIY on here about sealing up the trunk with silicone underneath the rubber or chrome. i'll try and find it for you. BAM---> http://www.cb7tuner.com/vbb/showthre...y+trunk+chrome
            I used a Bondo fiberglass kit on mine, hard as a rock and won't break, all I did is prepare the area, followed the directions on the Bondo box and laid it so it was up oneside and down the other. I tried regluar bondo but it broke and leaked again might not have been the right stuff either.
            Andrew
            My work in progress!
              Ah that's right! Forgot to mention the silicone sealing, used some window sealer on mine its been holding pretty strong for the past month
                I also forgot to mention that mine was a heft chunk missing, East Coast Canadian salty winter! Damn you salt!
