loud fuel pump
    loud fuel pump
    I think my fuel pump is going because it is loud
    When i have plenty of gas in the tank i can hear a high pich whine from outside the car. When im quite low on fuel i can hear a whine from inside the car but at a lower pitch. Is this normal?
    visit vgruk
    Not normal at all. You may be right, the pump may be failing. Have you listened closer to the pump to be sure that it's where the whine is coming from?
    For the time being, I wouldn't let the tank get low. The in-tank fuel pump is cooled by the fuel, so letting the fuel level get low will only make that pump heat up, causing it to fail even faster. (that advice should be followed at all times, but when the pump is likely on the way out, it's even more important.)
      Ok i will check that.
      Now if it is going out can i get one from a salvage yard or even overhaul the one i have?
      visit vgruk
        I wouldn't trust one from a salvage yard to last any longer than yours. I mean, you COULD, and you may be fine for a long time... but the amount of work needed to drop the tank and replace a fuel filter would be far too much to justify doing it for a used pump. That's how I feel, anyway. If saving a few bucks is worth the risk of having to yank it all apart again in the near future, then it's an option.
        I'm sure there are ways to rebuild the pump, but I wouldn't know how. I've never heard of anyone doing it on the forum here.
        Your best bet is to just buy new. New pumps on RockAuto.com range from $26 to $230.
        I'd suggest getting somewhere in the middle.
          Yea i was looking at one on rockauto for about $30. Me being a broke college student i always have to go for the cheaper option.
          I might replace it when it gets cooler and see if i can overhaul the one i have first. If it can be dont ill post a diyI have never ordered anything from rock auto before. If you feel like looking up the fuel pump list on there for my cb let me know the cheapest one you recommend. They dont sell "crap" do they?
          visit vgruk
            Fuel pumps http://www.RockAuto.com/m/mobilecatalog.php
            The one im looking at http://www.rockauto.com/catalog/moreinfo.php?pk=1400535
            visit vgruk
              It'll be more cost effective to have new one installed than have your old one overhauled, even if some one is willing to overhaul it.
              If there's overhaul kit available and doing it yourself would be another story.
              I replaced my Civic's FP with OE replacement from AZ last year. It was messy stinky job. I don't feel like doing it again. But my LX's FP is original and will go out sooner than I think.
              You want take out the tank completely. And you want remove all of crud and rust by blowing air into it. I used leaf blower for that job. You, not do this job, you may regret it later.
              A&P-IA
