fuel pump replacement
    I was driving up a hill today and my car died, it didnt sputter, it just died.
    it wouldnt restart , although it tried. I think the fuel pump died i cant hear it turn on and it was sounding unusually loud before this happened,
    my main question is do i have to drop the tank to replace the pump?
    yes
    A&P-IA
      Actually i have an older friend that decided to go through the floor of his trunk to get to the pump. He found the exact spot and used some kind of high speed rotary tool to cut the metal. He then cleaned up the metal, used some silicone and then got some sheet metal to cover the hole again. I forget how he secured the sheet metal though.
        Originally posted by oyajicool View Post
        yes
        Damn, really? I thought there was an access panel in the trunk underneath the carpet, that's how we got to the pump on my moms dodge neon. Guess that feature didn't cross over to Honda back in the 90's
        Hoonigan: a person who participates in any type of reckless driving including but not limited to drifting, drag racing, burnouts, doughnuts as well as acts of automotive aeronautics.
        MRT: http://www.cb7tuner.com/vbb/showthread.php?t=195250
          Its not even that serious.
            isn't there an access pannel in the tunk to remove the pump.
            1991 Honda Accord 2DR LX 180,000 Miles RIP
              There is a access panel but it doesnt go to the pump, it goes to the fuel level float or whatever its called.
                Ah, and I thought it was that easy, not having to drop the tank. I read some where that you could access it through the trunk area.
                I guess more work then.
                  What does that mean? There's an easier way other dropping the tank?
                  Thanks.
                    Out of all the fuel pump replacement questions i have seen on this forum everyone has said its just easier to drop the tank. I thing its like 2 bolts and some fluid lines right? Me...i would drop the tank. I hate working in small spaces
                    visit vgruk
                      its easy enough to drop...unless you have a full tank in there
                        Thanks.
                        No, what I meant was doing all that cutting and bullshit to get access to the pump is not even necessary. Everybody acts like dropping the tank is such a bitch when in actuality its not even that hard at all. I did the shit by myself with just a floor jack on the street... Trust me, it seems intimidating but its really pretty simple.
                        Lol, exactly. And there is a drain plug on the tank anyways so having gas in the tank isn't really a problem either.
                          Drain plug, so some one can unplug the tank and you can't drive the car. Lol.
