Hey there! I lowered my car this spring two inches with skunk 2 suspension! I replaced every thing imaginable. I took the tire off and notice on both sides the boots for the tie rod and lower ball-joints are completely torn. Everything else look grand! I only drive on my stock ex wheels. Should I have bought a high qulity joint and rod?
Lowered Car, Ball Joint promblem!
Joint and rod? Did you replace your lower ball joints, or your tie rod ends?
Regardless, any joint with a torn boot must be replaced ASAP. Seeing as the failure of any ball joint (upper, lower, front, rear, tie rod...) can result in a potentially fatal crash, you should always use quality parts. If I recall, OEM Honda lower ball joints are only $25 each. That's pretty darn cheap.
If the boot is ripped, it's very likely that dirt has already gotten in there. Once dirt is in the grease, it will lead to ball joint failure. The only time it'd be safe to just replace a torn boot is if you know the joint is good, and you damaged the boot yourself (and plan to replace it before driving the car again.)
when you get a poly kit the ball joints, its just the cover, does it simply go over the rubber on the lower ball joint or w/e u r working on?
There's absolutely no need to ever "upgrade" the ball joint boot to polyurethane. However, the poly boot replaces the stock boot. It should be used to replace an untorn, undamaged stock boot. It is not a fix for a boot that has been torn and has allowed the grease to get dirty. You'll just end up with a failing ball joint covered by a nice shiny poly boot!
My friend tore a boot while changing his axle, and he used a poly boot... but only as a replacement for a previously good boot. The poly boot didn't clamp down the same way the stock rubber boot did.
Replaces the stock boot. I thought it slipped over the rubber boot... so you will have to take the rubber off and put the poly one on. Didn't no how that worked.
