no clutch pressure
    no clutch pressure
    After I replace my motor I tried to bleed the clutch but couldn't get any pressure so I replaced the master cylinder and still nothing just fluid running through the lines so I switched out the slave and same thing. It just won't build pressure. If any one knows what's wrong please help cause I am a a loss right now.
    Just had that problem it's really just a hard system to bleed, all said and done after trying different ways to bleed the clutch my system took like 4 hours to bleed, including going to the store and buying materials. Check out my thread for the method I used to power bleed my clutch system
    http://www.cb7tuner.com/vbb/showthread.php?t=194184
      The one big thing I found when bleeding the system after replacing my clutch master is that you have to watch the fluid level in the reservoir VERY carefully. If you let it go too low, you will introduce air into the system which will then need go all the way through the lines to the bleeder bolt before it's gone.
      Basically, you will probably need to refill the reservoir after two applications of the clutch pedal. Really, it is best to check it after each pedal stroke.
        Thank you guys for the help I put a hose on the bleeder and put it in a container of fluid and maybe 5 min later I had full clutch I will always remember this trick
