I just testing the compression on my 226K mile CB7 though was told it had rebuilt engine 90K miles ago. What do you think #1- 179 #2- 176 #3-167 #4-172 cold engine. I will double check dry and with oil in a few minutes and test again.
Just did a compression test
From what I can find, it is a little bit on the low side of ok. Is it smoking or using oil? How does it run? If it runs good and isn't using/burning oil then I would drive it. Also, like you said, check it wet and dry and make sure the throttle is wide open and the fuel pump is disabled while doing the test. Let us know those numbers.Originally posted by deevergoteThat is exactly why pork chops don't taste like chocolate!
It seems low but at least evenly so. How long did you crank it for each one?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
No low would be anything below the service limit which is 130-140psi. Also all the cylinder's look to be within the psi variance, but a more accurate test is to do it on a warm engine.Last edited by SOHC-FTW; 09-27-2012, 12:25 AM.
02 Crv
I just picked up the car yesterday. No smoke the gal said it did not burn oil though I did find an empty quart container in the car. I did hold the throttle wide open. But did not find the right fuse to pull for the pump. I was told if you are W.O.T. the fuel injectors will not pump fuel while cranking. Not sure if this is true are not.Originally posted by Chevsica View PostFrom what I can find, it is a little bit on the low side of ok. Is it smoking or using oil? How does it run? If it runs good and isn't using/burning oil then I would drive it. Also, like you said, check it wet and dry and make sure the throttle is wide open and the fuel pump is disabled while doing the test. Let us know those numbers.
Seven revolutions each. I wish I had a helper to watch the gauge I might of gone a few more turns. Back when I was in the OLD SCHOOL with my small block Chevy the gauge just stopped increasing no matter how many revolutions.Originally posted by Jarrett View PostIt seems low but at least evenly so. How long did you crank it for each one?
Pull the ecu fuse.Originally posted by Kemosabe View PostI just picked up the car yesterday. No smoke the gal said it did not burn oil though I did find an empty quart container in the car. I did hold the throttle wide open. But did not find the right fuse to pull for the pump. I was told if you are W.O.T. the fuel injectors will not pump fuel while cranking. Not sure if this is true are not.
02 Crv
Yeah your compression numbers so far are pretty good. Are you sure #4 on that second test was correct? 1-3 are very close. Still #4 at 20PSI less isnt too bad if that is so, although it would be considered just a tad low in comparasin.Originally posted by Kemosabe View PostRetested with warm engine.
#1 184 #2 180 #3 176 #4 160
Seems a little odd 4 was lower than 3 when warm it was the other way around when cold..
Well just for kicks I am going to also check my D15Z1 Civic engine.ON_N20Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
Decent numbers although #4 is on the verge of the variance % compared to the rest of the cylinder numbers. Seem's like a normal healthy F22 to me as far as your test goes.
02 Crv
Well it is just for a daily driver with a long road trip throw in now and again.
I just hope it holds up for 20K miles are so more if lucky.
My Civic is great on gas not much else to say about it.
I bought the Accord for a little more comfort and I am planning on selling the Hatchback.
I already knew the Civic engine was a little more tired.
#1 152 #2 137 #3 140 #4 124
Rereading this post a couple of days later I can't come up with a single reason I might have given the OP for those being low numbers. Those are great for an F22A. Either I thought you were saying a different number, I misremembered the factory spec limit or thought you had an H22A. Either way, those are good numbers.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
