is there a difference in the 5 Spd transmission between a 1990 honda accord EX and a 1992 honda accord EX
Transmission Difference
I'm going to say no
http://www.cb7tuner.com/vbb/showthread.php?t=37839
but that link shows you the gear ratio on the H2U5 tranny found in the EX.
Look up part numbers. Different part number, different part. However, the gear ratios of all CB transmissions (at least all North American CB transmissions) are very similar, and the transmissions are basically interchangeable. You're unlikely to notice a difference if you use a transmission from a different year or trim level.
As for the VSS placement, if it is in a different location, it should still function exactly the same way.
The 1990 model CBs have some oddball things that the other 3 years didn't get... it can be annoying!
1990-1993 DXs, LXs, 1991 SEs, and EX Wagon's used the H2A5 Transmission. 1992 EXs and 1992-1993 EX Wagons used the H2U4 Transmission which was geared slightly more aggressively to take advantage of the extra power in the F22A6. Some 1992 DXs and LXs were stamped H2U4 but in actuality the gearing was the same as the H2A5. 1993 EXs and SEs used the H2U5 transmission which was the same gearing as the H2U4 but with the final drive of the H2A5.
H2A5
1st - 3.307
2nd - 1.809
3rd - 1.185
4th - 0.870
5th - 0.685
Rev - 3.000
Final - 4.062
H2U4
1st - 3.307
2nd - 1.809
3rd - 1.230
4th - 0.903
5th - 0.705
Rev - 3.00
Final - 4.266
H2U5
1st - 3.307
2nd - 1.809
3rd - 1.230
4th - 0.903
5th - 0.705
Rev - 3.00
Final - 4.062
Hope this helps....'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
