Plastic cap on windshield wiper assembly broke
    Anybody have this happen and find a way to fix it without replacing the whole thing?
    That is exactly why pork chops don't taste like chocolate!
    I've never even messed with that part... do you have a picture of the other side to compare how it should look?
    See how much you can take apart. You could probably use junkyard parts to fix it.
      If you look to the left of the missing one there is a dirty white cap on that one, that is how it should look with the cap on. The previous owner said that 2 years ago, during an ice storm, the windshield wipers quit working. Found out why, lol.
      I looked every where, even took the inner fender well off in hopes of finding it, I figure a person probably couldn't buy just that little cap.
        Bottom of assembly
        Top of assembly
          Check www.hondaautomotiveparts.com to see if they have individual parts available.
          It's amazing how similar that is to a window regulator. Interesting! If it's like a window regulator, you'll probably have to buy the whole assembly. That site also has some of the best prices for OEM parts.
            happened to mine... just went to the junk yard and popped a whole new arm with the caps still intact, its hard to get the caps out without breaking them and the dealer i went to didn't have the part in stock cost me 5 bucks
            MRT http://www.cb7tuner.com/vbb/showthread.php?t=188701
              It sucks having only 1 salvage yard in the area. They are WAY over priced and usually do not mess with small stuff, mainly engines and transmissions. When I lived in Wichita I would buy parts from the salvage yard all the time.
              I think I might tap the center of the ball, there is already a hole there for grease, and put a bolt with a washer in there until I find a replacement part. Thank you for the help!
              I think it is part #8
              http://www.hondaautomotiveparts.com/...NDSHIELD+WIPER
                http://i59.photobucket.com/albums/g3.../IMAGE_092.jpg
                Looks like he just welded a washer to the ball. Think I might do this. Probably have to grease it every couple of years but at least it will not break again.
                  Junkyard ? Might not be easy but It'll be cheap.
                  10th Anniversary Accord.
                  05 Audi A4 Ultra Sport 6MT.
                    Found the write-up!
                    http://www.cb7tuner.com/vbb/showthread.php?t=12341
