F23 Power Steering
    F23 Power Steering
    So I ended up buying the car that was discussed in this post: http://www.cb7tuner.com/vbb/showthread.php?t=195327. The car def needs some TLC in regards to the body and other aspects (260,000 on the clock) but I'll start another thread for all those pictures and purposes. Anyway, as mentioned in the other thread it's a f23a1 with an A6 head and aside from a slightly noisy valve train (think it may need some adjusting) everything runs pretty well. However, he deleted the A/C and P/S and normally that isn't a big deal for me. I drove around for a year before without P/S but since this is going to be my DD from now on I'd rather have it if I could. What is everything I'll need to get P/S back on the F23? He removed everything including the lines so I'll have to start from scratch. If it's too much of a hassle I'll just forget about and focus on other things like improving suspensions components and the body instead. Thoughts?
    The extent that the power steering system has anything to do with the engine is the bracket and the pulley. Since you've still got an F22A head, just use the F22A power steering bracket. That will allow you to use the entire system from a CB Accord.
      Okay thanks a lot, that was the extent of my concern. I just need find a full P/S system and brackets for the f22a1, correct?
