My right rear tail lights top and bottom do not work. I tried replacing the bulbs and no luck. Also the back window light isn't working either. Right now I am having a horrible trunk leak that I am trying to get a finger on. I am not sure if that has anything to do with lights not working. I am not sure if anyone has had this happen before. Also the rear brake light in the dash is on as well.
Brake Lights
I'm having almost the same problem and don't wanna make another tailights thread.
When I push the brake pedal, just the right trunk light turns on. The other 3 doesn't work. But when I turn the headlights on, the 4 bulbs works, but stays like low beam when I pump the brake, just the right (passenger) one on the trunk works good when braking. What's happening there?
