cb7 smells like gas..plzz help
    when im driving it smells like gas and its killing me... well not really
    but it has me worried i check all the fule lines and the pump and the tank and im at a lost... plzzz help
    Check to see if the fuel injectors at the rail and the intake manifold are dry andf not wet. Most likley its leaking there.
    Check it with the key on engine off.
    Retro!
    Hater
      thx. will do.
        I had a smell of gas on mine. Check my thread here.
          It could also be a bad catalytic converter.. Just throwing that in there as a possibility...
            My 91 EX currently has the same Problem. Although it only smells during the winter time or when it's cold out. My dad told me its because the cap where the fuel pump goes isnt secured with bolts.
              My old '90 had the same problem, the resonator was completely rusted through and blowing fumes up under the main passenger compartment... check your exhaust system completely.
                If someone has replaced the fuel filter recently they might not have put the new copper seals in or not tightend the lines going into the filter enough.
                Check the banjo bolt on the fuel rail aswell, injectors too as someone else said, they make injector seal kits for under $20 if thats your problem.
                  I had the fuel stench for a while. Come too find out in the drivers rear wheel well theres a fitting for the pressure line...it was leaking and spraying back too a good size rot hole in the trunk. Took me forever too find because i was set on it being under the hood. Ended up using braided line from the filter too the tank.
                    Yeah that spot is pretty common to go that fitting gets rusted to hell.
                    I would also check to see if your ignition timing is too retarded. In the winter though it's common at startup to perhaps smell some while it gets to operating temp. I notice that is when I tend to run rich.
