Windsheild wiper problem..
    All my fuses and in tact and when I turn on my wipers I hear a lil whinning noise.. What could it be? The motor completely shot?
    Are the wipers stuck to the window?
      They are at the down position.. they will move up and down manually.
        remove the nut holding down the wiper arms down, turn on the wipers and see if the spindle is spinning.
          thanks and if they dont then its the motor? just checking..
            Then we can move to removing the cowling and seeing if something came undone. I'd be willing to bet the spindles or the wiper arms are stripped where they bolt down.
              U know i didnt even think bout that.... Good call. Sorry im a newbie on all this..
                It's how you learn.
                  Sometimes the spindles get stripped by turning the windshield wipers on with them frozen to the windshield.
                  Its a good idea to thump them a few times when there is snow or ice on the car for this reason.
                    Just a bit of info man, from previous experience. I removed my plastic cowling (as djender put it), (learned something new), you can check out if there is debris blocking your wiper motor from functioning correctly. After that you can check and see if your wiper arms are moving correctly.
                    If you hear the wiper motor running and the arms aren't moving then check the nut that holding them down, at first i had the nut tooooo tight so they wouldn't move. I freaked out but then read on here that maybe i tightened them too much and loosened them up.
                    Now everything is running fine, just need to align the nossle heads to shoot on the glass lol.
