Another trans "s" light
    Hello all,
    I am pleased to be a part of this awesome site. Searched around and
    this one surpasses the others with ease. Anyway, s light came on and is solid. Pulled the 2 pin connector,installed paperclip,turned the key to the 2nd position and watched for blinks of the cel and the s light. Both solid and no blinking.Pulled the tcm and had a capacitor leaking and a resistor fried. Had it repaired and i'm about to install but I first need to know is there anything I need to do before I install. Had knee surgery, now I have a little time to dig into my newly owned Honda. Thanks for any responses. They are and will be greatly appreciated. Please excuse the long post.
    Nope your good. Disconnect the battery plug it in and fire it up, should work fine.
    -Will
      I was really prepared to give the usual "read the thread marked 'READ HERE FIRST'"... I'm pleased to see that you actually did!
      Yes, if everything was repaired properly, just install it. It's been disconnected from the power source long enough that it should have cleared any saved codes. Any new codes given should be legitimate, or an indication that the repair wasn't done correctly.
        Thanks a lot. Will be chatting soon. Be cool
        Thanks for the quick response.
          Another trans &quot;s&quot; light
          Hey guys, it's me again. Connected my tcm today and it started right up and ran fine for about 15 mins then the s light started clicking on and off. Staying on for about 5 mins and off for around the same. While the light was on I put the paperclip in the 2 pin connector(after I shut the engine off). Just before I did this I switched the car to the 2nd position to see if the s light was still on, it was. I proceeded and the cel and the s light was solid w/no blinks. Am I doing something wrong???
