Down Pipe gasket
    I had no idea of that gasket being sold at AutoZone, I am going to take back those Subaru gaskets I just bought and get those instead, they look like a perfect fit unlike the Subaru ones.
    Wish I had known this earlier but its all good.
    Btw does anyone know where to find multilayered gaskets like that for the rest of the exhaust system? The majority of all my gaskets are the crappy graphite type. The most important one is probably this one, this is found at the end of the downpipe going to the cat converter,
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    ― Jeremy Clarkson
      Originally posted by Quashish View Post
      So.... Whats wrong with the crush type gaskets? I just got this from auto zone. Fits perfect
      This is my first to learn about this type gasket. The last time I needed to replace eBay gasket, most of people were talking about Subaru gaskets.
      This crash gasket is blessing for those mechanically challenged people like me. I may pick one up myself when my modded Subaru gasket leaks.
      A&P-IA
        dear cb7tuner enthusiasts:
        THANK YOU
        yet again, any question unanwsered is resolved
        Just do what PR CB7 said.
          I just put in one of those subaru gaskets but noticed the downpipe bracket that bolts to the block had broken completely in two. So... does anyone know where to find one of those brackets? I looked but found none.
          EDIT: I looked on the honda website and the diagram doesn't have it.
          Edit again, sorry if this is OT, i'll post in my thread.
          ― Jeremy Clarkson
            The general consensus is to not attach it when using an eBay header. Or at least attach it with a flexible mount.
              Why is that, wouldn't that put too much strain on the headers? I am not talking about the bracket on the downpipe, that already broke off and I had it re-welded, so there's no way the bracket there is going to come off. What I am talking about is the bracket that is a separate piece. in this diagram its #12
              That piece broke like it was nothing.
              ― Jeremy Clarkson
                Uh.... It's #11 or #12 in the diagram. I know an A1 uses #11 and an A6 uses #12, can't say for sure on an A rare.
                Depending on the header design, you MAY have to use the bracket. On my megan header I didn't, and no issues. With my header from DNA motoring I did, otherwise the header would sag and hit my crossmember.
                  I'm using the A1 (#12) bracket with A6 downpipe, that's probably why it broke in the first place. #11 is different from #12. Do you think I should get a #11 like the catalog says or would a #12 work? But I can't find the #12...
                  ― Jeremy Clarkson
                    On my 4-2-1 header installation, I used that bracket (#11 or 12) after knocking off those studs on the bracket, turn 180 front to back and bolts and nuts in place of studs.
                    A&P-IA
                      How did you even get it to fit? The 12 bracket is offset to the left by about an inch, inch and a half. You would REALLY have to muscle it over to get it to fit. Use the bracket that matches your down pipe. I just installed a DNA header onto dvswoo's A6, and we had to swap the bracket over to an A1 bracket.
                        Metal stress fracture
                        A&P-IA
                          So should I get another or go without it? Or should I get the one for the A6? If so where can i find the A6 bracket?
                          ― Jeremy Clarkson
                            Off ANY A6.....
                              Honda engineers thought it was needed to have the bracket there. You could find it at JY, no?
                              A&P-IA
                                Off ANY A6.....
                                I don't have the resource to find an A6 bracket easily.
                                ― Jeremy Clarkson
