Turn signals, dash lights, taillights WONT WORK!
    so just to sum this up a bit, my radio stopped turning on, when it came back on my tail lights stopped working (brake lights work) but the taillights will not come on. a couple of days later after turning off my car at the gas station and turning back on i noticed my turn signals were not working, not even on the inturament cluster. as for the dash cluster the lights do not come on but the door lights (which tell u if door is not closed) work as does the other "problem" lights.
    im not sure where to start with the problem besides fuses and light bulbs (which i already checked). not sure if it has to do with a short somewhere, or even a relay which i dont know how to test for...
    i miss driving my CB but i get tired of using my hand for turn signals!!!
    See if your hazard lights still work. If your dash lights don't work your front running lights don't either. They are on the same circut. Cluster/tail/ and running lights. If your hazard lights work I would think the switch is bad.
    ......father in law has it back again. Time to shine
      now that you say it i dont think that the running lights work either! its hard to see right now as its bright as hello outside and my running lights are tinted dark! so if the switch is bad where can i locate that switch at?
        check the small light fuse in the engine bay. sounds like your problems started with the radio. check that wiring too.
        COUPE K24
          well see i have already checked the fuses, and none of them are blown that's why i am going crazy!!
            you checked both fuse boxes?
            COUPE K24
              well i checked both fuse boxes, and sure enough u were correct the "small light" fuse was blown not turn signals work as well as back lights! just not sure about dash lights (to bright outside right now) but thank you so much!
                if the running lights work, the dash lights will work.
                no problem, it happened to me before.
                COUPE K24
                  ditto that check the fuse box
                    OK, I know this sounds dumb but try replacing all fuses relating to lights and cluster.
                    i had complete dash failure including cluster, dash clock, and P/W. i checked both fuse boxes. all my fuses "looked" Ok. relays looked good too. 3 days i drove around like that until I bought new fuses changed #1 (controls cluster), and other fuses in the underdash fuse box and some more like p/w fuses in underhood fuse box.
                    instant success..
