I had an issue about 2 months ago that started as engine stalling and jumping in the rpm's, so I parked it and found that the spark plug ring gaskets on the valve cover failed and drained oil into the plug cylinders. I replaced the gaskets, cleaned the oil out and bought new plugs, new distributor cap, rotor and coil, all installed and working correctly. I started it and it was backfiring out of the intake, so I cleaned out the EGR valve and it stopped. I charged the battery and it started perfectly, idled great and ran. So I shut it off and now it wont start for more than a few seconds. It jumps to 1500rpm then slowly dies. If I give it gas it dies immediately. Any ideas are appreciated. There is good gas in the car and the plugs are sparking bright blue, so I'm stumped.
Need help, engine stalling
The tach isnt erratic, it just sits at 1500 then dies down steadily until the engine stalls, kinda live a missing vaccuum line but all the hoses are good and sealed. I havent checked the plugs since I only started it once but spark was good and consistent before I started it the 1 and only time since the repairs. I've considered timing but having had badly timed cars before this doesnt seem the same.
The CEL isn't on and the ECU isn't flashing any trouble codes. The fuel filter sounds like it may be a good thing to check lol. I'll buy a new one and see what happens. If not I can't imagine what else it might be. I've never experienced this problem before and without trouble codes I'm at a loss.
Mine was doing a routine of revving from 1100 up to 1500, and back down to 1100, over and over. My solution was replacing the IAC valve, and adjusting a screw. Don't remember which one, it wasn't the throttle rotor though.
VTEC by birth, not be choice.
Andy's Auto Sport: Comptech Battery Tie Down, "It will look so trick that your car will think it has more horsepower!"
DumbleDore!'s CG
http://www.cb7tuner.com/vbb/showthread.php?t=199312
absolutely yes.Originally posted by Corbenick View PostDoes the fitv have anything to do with erratic idle?
When you start the car, does it start rough ? or idle rough ? Sounds like fuel system.Last edited by tutsuo; 03-01-2013, 09:40 AM.Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
Originally posted by deevergoteden das al u ned u no dat u get wurs gas milge tho rite?Originally posted by deevergoteThese cars will never be the best at anything, but they're pretty damn good at everything.
