I have a 91 accord ex and I'm wanting to put better sway bars on my car. I know some of the newer accords you can use the sway bars from the tsx, but are there any cars that I could pull the sway bars from that will fit on my accord?
better sway bars
'94-'97 Accord EX
'92-'94 Acura Vigor
'97-'99 Acura CL
possibly the '96-'98 Acura 2.5/3.2TLs (the rear ones do for sure)My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
From what I have read, the best bet for better Sway bars would be ST or Progressive. It seems most people on CB7 that I have researched like the ST bars, but you need to drill two holes on both sides to make them fit.
You would also have to give us information about your suspension to be able to give sound advice about what would give you the best results. Along with that what are your goals with your car? Is it just for street? like track or auto-x? Full blown racer?Last edited by axle; 02-19-2013, 03:01 AM.
It's a stock ex for now. Just street driven. I will be putting on some skunk2 coilover struts after I get some more stuff together. I would think about doing an aftermarket sway bars but I just don't have the money be able to. This weekend I'm going to be getting the rear trailing arms from another accord that has rear disc brakes and not drums and it will he easier if I could find a better sway bar, then my stock one, at the junkyard.
Unless you have an LX wagon then your rear drum Accord doesn't even have a rear sway bar. If you get the rear suspension off of another Accord to get rear discs then get the sway bar also. Or, get the suspension like planned and get the rear sway bar from one of the above listed cars.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
If this true then what is the bar that runs from side to side in the back and everyone says that the EX has a rear sway bar?Originally posted by Jarrett View PostUnless you have an LX wagon then your rear drum Accord doesn't even have a rear sway bar. If you get the rear suspension off of another Accord to get rear discs then get the sway bar also. Or, get the suspension like planned and get the rear sway bar from one of the above listed cars.
My bad. I thought I remembered from your first post you saying you had an LX. I was actually posting this in my 6:00 AM meeting from my phone with it under the table.
You're right. You already have a sway bar. It's a 14mm. The ones I listed are 16mm. You can also get some Urethane bushings for the Accord and drill them out to 16mm, which is what I did. I'm also in the process of developing some solid end links for rigidity.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
In the ones I was sure of. What makes you think you need a bigger front bar, though?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
IIRC, stiffening the front will increase understeer on the cb7. You don't want to do this because the car already has excessive understeer. Therefore, a rear swaybar will decrease understeer. If you want more neutral handling (no oversteer or understeer), then you will just need a bigger/stiffer rear sway bar.Originally posted by demigtod View PostNothing I was just thinking about grabbing a front one also for a little better handling.
A good quality spring and shock combination or a set of coilovers. And making sure all of your bushings and ball joints are good.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
