My apologies in advance for my first post....
Car: 1993 Accord 10th Anniversary 4DR with Power Windows
Problem:
The front power passenger power window does not roll up or down as the window motor does not operate. At first I thought it was just the binding of the regulator/tracks but when I removed the motor I confirmed it did not work. So I bought a new motor and replaced it but the new motor did not work as well.
I then tested both motors with direct power only to find out both motors worked just fine. Must be the switch, right?
I tested the connection from the switch to the motor and there is power but the motor will not operate. I can confirm there is power when the front passenger or the driver's master switch is activated. I also made sure the window lock is not activated.
Have I missed any troubleshooting steps? Any suggestions?
Problem:
I then tested both motors with direct power only to find out both motors worked just fine. Must be the switch, right?I tested the connection from the switch to the motor and there is power but the motor will not operate. I can confirm there is power when the front passenger or the driver's master switch is activated. I also made sure the window lock is not activated.
