HID system only passenger side works, drivers sides flickers then shuts off wires have power but I don't know if its the ballast, bulb, or just low power to that side.
HID Flickers and then shuts off Drivers side only.
Could be any of those things. Is it a cheap kit? Cheap kits will die in time... that's why they're cheap!
Do you have an auxiliary harness to the battery? Or are you running only on the stock wiring? If it's just on the stock wiring, you may have damaged the harness, as HIDs draw more power than the wire harness was designed to handle while they're warming up. Seeing as it's the side furthest from the battery, that's a very real possibility.
This is what you need
I had the exact same problem and I have a very decent HID kit.
http://www.ebay.com/itm/Xenon-HID-Co...422a8f&vxp=mtr
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
Are you connecting the ballasts to the stock halogen connectors? if so, thats going to be your problem and you run the risk of torching the wires.
Run power to your fuse box, or better yet to the battery and then ground each ballast to either grounding point in the headlight well. try that and see if it does the same thing. If so, try swapping the ballast from right to left and see if the other side experiences the issue. If so, you have a bad ballast.
Cheap kits will do this. Had a cheap set of DDM awhile back and it had the same issues. Switched ballasts and it went away. TBH, on newer cars, 35W setups wont do damage so long as they're not on ALL the time. But the CBs are too old to take that chance so as said, I'd recommend a harness. Even for a 35W system.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
