mount help????
    mount help????
    I am new to this. Im going to be swapping the f22 out of my 92 Lx and swapping in an f20b ( sh cams, h22a trans ). i dont have the money for innovated at the moment and i have seen on honda tech making your stock into innovated and i like them better then i like after market. can anyone tell me the stuff i need to make them innovated.
    "Innovative" is a brand of aftermarket mounts made from fabricated steel and filled with varying grades of polyurethane. You cannot do anything to your mounts to cause them to become aftermarket mounts from Innovative.
    What you likely saw was people filling their OEM mounts with a substance called window weld. That is a light grade of urethane available at home improvement stores in a calk tube. You basically just fill the voids in your rubber mounts with that material. It won't be as stiff as urethane mounts and will also not really serve the intended function as well.
    Also, SH cams are the same as regular H22A4 cams.
