Tachometer help!
    Tachometer help!
    I have a 1990 accord f22a4 and I can't seem to find the signal for the tach I know it should be the blue wire coming from the distributor but I connected it there and it got no signal can someone help me out with this please
    A little more info, are you using a stock tach, aftermarket, new or used?
      It's an aftermarket faze tachometer
        New or used? black to ground, red to power and green (i believe) to the dizzy blue signal wire. if this doesn't work then if new ..return it and if used.... well, a good paperweight and I hope you did not pay much for it. if you do not have a stock dash tach you may want to consider swapping in a cluster that does. Generally run about $200 to $250 at the wreckers and will function just as good. Most aftermarket tachs ($excluding high end$)are generally no more accurate than a stock one anyways, tolerances can be + or - 500 rpm with some. so if it has a shift light and it is set to close to redline (yes some people do that) you could actually be well past it and think your safe.... Always best to test and calibrate any new tach install and not take it as a given. Hope this helps
          Should be the blue wire in the 2 wire connector. If you're spliced into that wire and it's not working, your ground wire might need to be relocated.
          98' Mustang 3V Swap
          11' VW CC R36
            I got it now thanks!
