View Post
91 DX idle
Originally posted by deevergote View PostI own all 3.
The Helm manual is the official Honda shop manual. EVERY diagram, every torque spec, every part number... all 100% correct.
The Haynes manual is slapped together by mechanics that are not experts on these cars (a member here actually knew the guy who wrote the book... said he halfassed EVERYTHING!) The info is detailed in some places, sketchy in others. It's good for basics, and probably fine for most things, but not a great book.
The Chiltons manual is absolutely worthless. It covers Preludes and Accords from 1984 to 1995. That means it covers three generations of Prelude (some 4ws), and four generations of Accord (sedan, coupe, hatchback, and wagon models). It covers the ES2, A18A, BT/A20A (both carb'd and fuel injected), B20A, B21A, F22A, F22B1/2, H22A1, H23A1, and C27A4 V6.
So yeah... that's a shit ton of "similar" cars to cram into a single book.
Originally posted by roland lorenzo View Postthat vertical tube is only a breather and the hose plug with bolt is a vacuum line. it's better to start with thermostat, get a new one. Don't forget to flush and re-bleed your cooling system also tighten the plastic lock inside the FITV.
When I pulled off the old thermostat I was greeted by a nasty crap build up in the metal pipe it falls on to. I am guessing this is a coolant passage though the block so to clean it out I could shove my power washer in it and blow all the crud out. Is that safe, or should I do clean it some other way?
Also, for the water I put into the radiator, I should use Distilled correct? That is what I used in my computer's water cooling so bacteria wouldn't build up so I figured it would be good to use it in my car to keep everything clean.
