First step is to figure out if the fan is hotwired because of a problem in the original wiring/circuit or if it's because there is no wiring....
Have a look around the front of the engine bay (passenger side) around where the air box was to see if you can spot any wire connections that are not connected. It should be around/below the coolant overflow reservoir.
Report back if you can find the wiring connection.
