I got a really good deal on a (f23a1 Vtec) with less than 100k miles out of a 99 accord. The (f22b1 Vtec) in my 96 accord is blown so I got the f23 to swap out.
To the best of my knowledge the trans will bolt right on and the motor mounts are the same. If i remember correctly I need to plate off the IAC and i think there was a knock sensor or something on the back side that i may need to plug off as well. I might have to swap the f22 Disi and i think spin the fuel rail around.
Please feel free to correct me if I am wrong here. As a little background I had a boosted H22a in a 90 accord that i built from the ground up but that was in 2004 so a lot of the details are blurry. This swap is very similar to the H swap but with a lot less cost and a lot more room in the engine bay.
So do I have the basics correct?
I do have a chipped ECU but it has a boosted h22 map on it so I would have to get a new map burnt on to my chip unless the f22 ecu will work. This i am not sure of.
So any ideas from you guys?
