are the ecu's the same between a f22a1 and f22a6? If they aernt the same will using the f22a1 ecu on a f22a6 effect the performance or the engine?
f22a1 ecu with a f22a6
The f22 a1 comes with the pt3 ecu. The f22 a6 comes with a pt6 ecu. The f22a6 will run on the pt3 but the pt3 does not control the Iab's that are on the f22a6 and is not designed to run the bigger cam on the f22a6. It's a good idea to utilize full potential use the pt6 ecu with the f22a6.......father in law has it back again. Time to shine
Yes i have the f22A6 intake.the vacuum box that is bolted on the bottom of the manifold is gone though.Originally posted by deevergote View PostYou won't really risk any damage with the PT3, but you'll be missing out on a good deal of power without it. Especially if you're using the F22A6 intake manifold.
Mine had a pt3 on the f22a6 for about 8 years with no issue. You will want to at least operate your iab's by intake vacum. The best way is to get a box and run wires to your new pt6 ecu. I don't remember which ecu pins but the process has been covered many times on this site.......father in law has it back again. Time to shine
Originally posted by cb7 calling View PostMine had a pt3 on the f22a6 for about 8 years with no issue. You will want to at least operate your iab's by intake vacum. The best way is to get a box and run wires to your new pt6 ecu. I don't remember which ecu pins but the process has been covered many times on this site.
thanks i will go pick up the ecu this weekend and i may have the vacume box on my extra f22A6 intake manifold
The pt3 was designed to run without Iabs. If its not running well its not because of the pt3 unless its an a6 and has the cam that came with the a6. Even then I have ran my a6 with a Pt3 and the difference wasnt noticeable other than the Iabs not working.Originally posted by hotrodj View PostIve got a Pt3 running a F22A with a A1 non iab intake mani. Runs fine. Dosent run "great" ,but runs fine otherwise.
