What happens is I can start it one time and it starts perfectly, Drives just fine. But after I take it around the block and park it in the driveway and kill it, and try to start it again, it starts but then dies immediately after. If I let it sit for like 30 seconds, it usually starts just fine. Any help would be greatly appreciated. Thanks.
Engine Dies
Originally posted by oyajicool View PostThis site may shed some light to your question.
http://techauto.tripod.com/
Originally posted by J_Hart View PostIt's quite simple to pop the cover off the main relay and look around. Both times my relay has died, I could easily see a burnt solder point, and both times I re-soldered. (different connections) Saved myself $40 each time.
Originally posted by J_Hart View PostI don't see any obvious signs of arcing in that pic, though that's not to say something inside one of the relays hasn't gone bad. Does everything look good on the top side as well?
