Has anyone every swapped a b series into a cb? My f22 is dying and I have a b18 just sitting in my garage, so... I was just wondering. How difficult of a swap would it be? (I haven't seen a b swapped accord, So I thought I would ask the accord world.!
b18 Accord?
I've never seen it done. The B series engine will NOT mount to your F series transmission. If you are doing a swap, you will need motor mounts, trans mount, and a ton of customization to get it accomplished. For the power of the B18, it's probably easier to just swap the F with an H motor as the transmissions on the H and F series are interchangeable. I'd say forget the B18 and go with the H. More power, and easier to install. Just my 2 cents.
Why would you decrease your displacement by almost half a liter?
The Accord needs torque to move, B series aren't really torquey.
The Accord is too heavy for a B series.
IMO sell the B18 and get a F or H series motor.
Not to mention all of the custom wiring to do a B18 swap.
A B18 swap in a Accord is like putting a F20C in RWD R33 Skyline, but worse.Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Instagram: @CB7Nub
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
The B series has plenty of torque to move the CB7. In fact, the CB Accord came with an F18A in other markets.
The problem is, as stated, that the B will take considerable modification to work. Custom wiring, custom axles, custom mounts, and a hell of a lot of cutting of the firewall and floorboard to accommodate the rod-shifted transmission (since the Accord uses cables.)
H and F series engines are your choices for easy swaps. Anything else is going to take a good deal of work.
Also, the RWD R33 and S2000 weigh almost EXACTLY the same. The S2000 may even weight slightly more. An F20C in an R33 would result in a lighter car than the S2000.
EDIT: ^Uh yeah what he said. Dammit deev go to sleep! Your killing my Graveshift boredom post.
The B18 has more than enough power to move a CB7 accord. People forget that the weakest motor that was ever offered in the CB7 was a JDM SOHC F18A motor. This F18 motor is even weaker than the first generation JDM B18 motors that were found in BA/CA accords.
A more modern F18B is even offered in the last generation prelude,JDM accords and torneos etc. Being a 1.8 liter wouldn't necessarily mean it will putt-putt around like a go-kart.
The only thing keeping this from being a normal swap would obviously be mounts and possibly linkage.Last edited by Warudakumi; 06-15-2013, 04:56 AM.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
