cooling issues got me crazy
    Ok, so he is the issue. I have a 92 Honda accord with 281k on it. I recently installed a new thermostat in it because it was overheating while i was driving and when I was sitting a stoplight. Now since then the temperature gauge will go 3/4 of the way up and go back normal.The next morning I will have to add coolant or water in it to bring it back up to par before I go anywhere.There is also boiling coolant in my recovery tank not to mention the temp gauge would show cooling down when i decreased in my speed.your thoughts and opinions are very much welcomed thanks.
    Likely a head gasket issue, but i would recommend pressurizing the system and a leak down test aswell.
    02 Crv
      Make sure that your cooling fan is turning on, could of been your initial issue. Make sure you bleed all of the air out the cooling system and while bleeding the system make sure that your heater is on. If you ran it too hot you might have a blown headgasket like he said.
