Automatic transmission problems
    I noticed a few months ago that my car would take sometime to shift in to park (the light on the dash) and also i could feel it shift into drive but when i gave it a little gas i could then feel it start to pull.. then last night when i stopped at a light it didn't full pull like it wa in the wrong gear or something i put it down into 1st my self then put it back into D4 and it changed fine the rest of the trip then it did it a few times today. I am having the fluid changed today. anyone know what it could be? Thanks Y'all
    Is your S light (90-91) or D4 light (92-93) flashing? If so, that's an error code. The thread marked "read here first" will tell you how to read it.
    Are you having the fluid replaced with Honda fluid? If not, you should. These automatic transmissions are very sensitive to the proper fluid.
      Sorry i thought i wrote that... It;s a 1991 EX. No my "S" light is off And i did just put a new Speed sensor on it because of the S light code & Speedometer acting crazy
        In that case, you're a step ahead of the game. Many people aren't aware of the error codes, or how to check them.
        Change that fluid with Honda ATF, and see how things go from there.
          Ok, It's getting done today @ Honda. praying it takes cae of it. I have done called around and have yet to find a replacement trans :/
            There are TONS of CB7tuners in Florida, along with owners of other compatible Accords. Get your post count up (without whoring) and you'll be able to ask in the local classifieds section. You could also hit up the FLAccords Facebook page. Lots of good guys on there to help you out.
              Today the "check" light came on and the "S" light came on.. The "s" light gave code 4 and then 8 the Check light gave code 17 & 43
                New shift solenoid & Fluid change and its shifting fine
