electrical problem
    electrical problem
    While im driving the battery light will blink once and a while on my cluster when it does that my lights either go really dim or they get super bright i had a battery test/alt test done all the readings were fine on the head unit it comes up error-ao once the battery light blinks once the music still plays i just cant change any settings can anyone help?
    If it goes normal to dim and back, it suggests faulty electrical connection(s).
    But since you are seeing "super bright", I tend to think faulty voltage regulator on the alternator.....
    Intermittent problem, so it doesn't show when tested.....
    Maybe.....
    A&P-IA
      When the cluster lights get bright all the power stuff has alot of power windows wipers etc
        Sounds like it is most certainly the voltage regulator. Replace it soon before damage is done to your electrical system, primarily the computers.
          Its the plug going into the regulator one of the terminals is loose lol
            Good find!!!
            A&P-IA
